I am having a problem doing a random function on two pins. I am using 16 audio tracks set up an init file using pins 5 and 6 for the two pins for the random functions. Pin 5 I have set up to do random range tracks 5 through track 8. Pin 6 Random range track 9 through 16. What is happen is pin 5 random work OK but 6 is doing the same as pin 5. I can’t seem to get it to work the way I want it to. I need help got to this working before the 12 th of September.
Please post your ini file here.
