I’m struggeling to get the external tempsensor (Soil temp) to work. In the log it’s only showing the numbers -0.119999 for all readings and when I used your code for Experiment 4 and placed the sensor in a glass with warm water or cold water the value the Micro:Bit showed was 0, all the time. I can’t get the sensor to show any right value even if I reset the Microbit, checking the connections to the sensor and so on.
Anyone else experience the same with the external temp.sensor?
