what is TH. pin?
On ATmega88 AVR, there is a pin called TH. standing for thermal. What is it for? I could not find any information about it in datasheet. Thanks
smdfan
I can’t find it. What is the pin number?
I’m assuming this is what someone labeled the pad on the QFN and MLF parts, which should be grounded.
TheDirty:
From EAGLE’s schematics, the pin is labeled as TH (Thermal). On board layout there is not extra pin labeled as TH but underneath the IC, there is an area. I am not sure if this area is supposed to be grounded or not. I think it is meant to dissipate heat from IC. Thanks
That pad is grounded, on most QFN chips.
leon_heller:
It is not QFN but TQFP type of IC. Thanks
I don’t think that any AVR in TQFP has a pad. What is the part number?
