Hello, if I intend to use the amplifier with a S-type load cell of 300kg, what is the recommended weight to use to calibrate using the SparkFun_HX711_Calibration sketch?
What is the recommended weight [in g/kg] to use to calibrate the Load Cell Amplifier HX711 Breakout?
If it’s a 300kg load cell and you plan on loading it close to 300kg, I’d find a weight close to 300kg to calibrate it with.
I wouldn’t mess with any less than 10% capacity and would feel a lot better if I could scare up 50 kilograms.
