what lcd goes with sparkfun-project-case-sku-WIG-08601
I like the box,
now I need to know what LCD you had in mind when you created it.
SparkFun Project Case - Black
sku: WIG-08601
Q: What LCD fits in the front of the box?
jp
It doesn’t look as though it was designed for a particular display. You will have to find a display that fits the removable panel and get the panel machined for it.
Leon
hmmm.
It is a very nice plastic insert. Very slotted and nice.
It hard to believe it wasn’t set to some standard.
I hope someone can enlighten me.
If it was machinable, I wouldn’t think they would slot it so nice on all 4 sides,
but I could be wrong.
I want it to fit an LCD2S-162BIW, but the hole is slightly too small.
rgds,
jp
That panel was designed to be drilled / dremeled out to fit the connectors of your choice. As far as I know, there is no LCD that fits there. The slotting is so the panel can easily be replaced; assuming the first one gets messed up during cutting.
Cheers,
–David Carne
tanks
