Where to get my PCB mounted.
Hi
Looking for a company there can put all the components on my PCB. It is about 25 pcs. in the first batch, and then 100 in the following.
It will be nice if the company can do all the production, maybe order the standard components(resistors, and so on…) too, I will then supply with the special components.
Most, if not all, board assembly houses don’t want to be bothered with lots this small. If you were wanting 500 or 1000 quantity they might decide to give you a bid. If an outfit does gives you a bid for 100 pieces then you will pay very dearly per board.
Hi there,
I have used www.ezpcb.com in China for both board manufacture and population for as small a run as 6 boards in the past. They purchased all the parts and then mounted them for me. No issues with any of the boards I have had made.
Contact nila@ezpcb.com and tell her Dave from Axon Instruments gave you her contact details. I am sure they will be able to help you.
Dave…
PS… I don’t work for them, I am just a happy customer.
I don’t want to sound like I work for them, but some of my friends use ezpcb. I personally like to do the work myself since it costs less and its really fun once you get a hang of it. I only just started to use batchpcb for my boards.
