Which connector for Flexible Grayscale OLED
I am working on a design that uses the grayscale flexible OLED breakout (https://www.sparkfun.com/products/14606.
Although I can use the breakout, I find it a more elegant solution to incorporate the components on the pcb that I am designing. My question now is: which connector is used on the breakout board? I downloaded the eagle files and have the footprint, but a part number for the connector itself would help me a lot.
Hi Boeld,
We have the connector part number listed in the SparkFun Eagle Library as “AYF331335”. If you would like, we have instructions on how to download and install that library in [this tutorial. I found this connector in the OEL_1.8 package in our “SparkFun-Displays.lbr”.
I hope this helps with your PCB design.](How to Install and Setup EAGLE - SparkFun Learn)
