wifi and LoRa
Have you worked on a project where you needed both WiFi and LoRa on the same board? I haven’t found very many boards that offer both. One that I do have is the [LILYGO T-Beam. It isn’t all that easy to find information about and programming examples are scarce outside of their github.
Would you start with an Arduino with builtin Wifi and add an external LoRa board or vice versa?
Thanks for any thoughts or ideas or stories of past experiences.](Amazon.com)
You could use something like https://www.sparkfun.com/products/18573 - scroll down to see ‘hookup accessories’…you’d need either a single or double function board and a MicroMod style processor…I’d recommend getting the LoRa board linked above, a single function MicroMod board, and an ESP32 MicroMod processor (has WiFi) and you should be good to go :slight_smile:
