I am trying to think of a way to wirelessly power-on a project that is primarily sealed. This would enable the project to be turned on/off without opening the case (until it needs to be charged)…And I cannot simply put a switch on it…Think something like sphereo does. You never actually have a on/off switch…
I was thinking maybe a Particle Photon and a relay. The Photon (or other suggested board) would wake from a wirless trigger and fire off the relay to turn on the overall project…I could use a separate, smaller, battery for the Photon I guess…
Does this seem like a reasonable approach? Is there a better choice of dev board for this (instead of the Photon)?
Thanks!!
