I have been trying to have a play with WinARM and Programmers notepad, just to get a feel for it and have run into some problems, basically I can’t get anything to compile, even any of the SFE device firmwares. I thought I found a fix on the net with environment paths but then it just changed to a new error.
Current errors are:
Compiling C: main.c
arm-elf-gcc -c -mcpu=arm7tdmi-s -mthumb-interwork -I. -gdwarf-2 -DROM_RUN -D__WinARM__ -I -Os -Wall -Wcast-align -Wimplicit -Wpointer-arith -Wswitch -Wredundant-decls -Wreturn-type -Wshadow -Wunused -Wa,-adhlns=main.lst -ISYSTEM/ -ILPCUSB/ -Wcast-qual -MD -MP -MF .dep/main.o.d -Wnested-externs -std=gnu99 -Wmissing-prototypes -Wstrict-prototypes -Wmissing-declarations main.c -o main.o
main.c:62: fatal error: opening dependency file .dep/main.o.d: No such file or directory
compilation terminated.
make.exe: *** [main.o] Error 1
or on the SFE UberBoard firmware
Size before:
0 [main] sh 10304 sync_with_child: child 9544(0x118) died before initialization with status code 0x0
19727 [main] sh 10304 sync_with_child: *** child state waiting for longjmp
/usr/bin/sh: fork: Resource temporarily unavailable
make.exe: *** [sizebefore] Error 128
I am thinking maybe I should just buy myself a nice older laptop with XP. Then at least I will have serial and parallel ports.
Is anyone here successfully using WinARM on Vista?
