Hello ,
Does anyone know how to use WinARM with Olimex USB-OCD ? I see on the Olimex website that they are making a installer for WinARM , is there any similar open source available?
Hello ,
Well I tested out the debugger using Crossworks (eval version). I compiled in WinARM and generated an .elf file which I fed to the Crossworks using their external compiled project option.This works as required.
Does Eclipse/Gnu support this option ? I was not able to check the same.
Any help would be appreciated.
