Hi, new here so big hello ![]()
Am also new to Wireless and quite new to micro controllers
Im looking to transfer an audio file from a computer to an audio player module. It will be a wav player (For simplicity) reading from an sd card.
So what im looking for is the best route (for a begginer) to go in transfering the the audio file (i estimate it will be about 10mb) to the sd card and ideally it will over write the existing file each time.
Ive got quite a steep learning curve to get through here but there is no rush so hoping to undertake this as a means to learn as i go.
Any suggestions on where to start would be apreciated.
Edit, thought i should add im looking for a range of around 50 meters and generally looking at the budget end of things.
