Is it possible to use the Wireless Power Transfer Rx Coil Module (WRL-15934) to wirelessly charge a battery which plugs into an Arduino?
The WRL 15934 outputs 12V, 1.25A
The Arduino’s voltage input should be between 7-12 volts.
Basically, I’m confused about which battery and charger I should buy from sparkfun.
              Greetings. Thanks for posting.
I would imagine that if you had a battery that would accept wireless charging then this could be a solution, however, I can’t recommend a battery and charger that can do this.
If you are looking for a wireless battery charger solution for Arduino I regret to say that we might not have the best solution for you.
Sorry about that. Please let me know if I can do anything else.
