hi there,
anyone knows if i could run an xbee module (serie1, 1mW) directly from the Vcc pin of an Arduino pro mini 3.3V ?
can it supply the current? does the 8MHz clock (instead of the 16MHz) - should cause any problems (with respect to the xbee communication, and the servo library) ??
which of these configuration is better:
- xbee + 3.3v regulator + arduino mini pro 5v
or,
- xbb + arduino pro 3.3v
