Hello all-
I’m new-ish to electronics, and new to XBees. I purchased 2 XBee 1mW Chip Antenna, and the XBee Explorer Regulated. I have plugged the explorer into my FTDI USB cable(which works fine on other devices), but cannot get any response from the XBEEs, either through putty or X-CTU. After making the putty connection, I get no response after typing the +++ that should get a “OK” response. With X-CTU, I get “Failed to enter command mode Unable to read Version (ATVR) Read parameters…Failed.” when trying to read in Modem Configuration, and “modem type = Name unknown” when using the “Test\Query” option in PC Settings.
Any Ideas? If I left out any information, just let me know.
Thanks in advance!
BW
