Hello everyone, first time on the SparkFun boards. Sadly, my first post will be a plea for help, but I promise after that I’ll try and haunt it as often as I can to help others ![]()
I recently picked up [XBee 1mW Wire Antenna - Series 1 (802.15.4) along with [XBee Explorer Regulated and finally the [FTDI Cable 5V VCC-3.3V I/O cable to configure it.
My problem is that I can’t get X-CTU or PuTTY to talk to the XBee using the FTDI cable and the explorer board. The power light comes on the board, but DIN and DOUT remain unlit at all. I’m in the dark on how to test what’s not working. I got two XBees for my project and neither work, so I doubt it’s that (unless it was a faulty batch).
Does anyone see something obvious that is incompatible here? At this point I’ve gotten quite frustrated and I’m at my wits end. Any insight is greatly appreciated.](FTDI Cable 5V VCC-3.3V I/O - DEV-09717 - SparkFun Electronics)](SparkFun XBee Explorer Regulated - WRL-11373 - SparkFun Electronics)](XBee 1mW Wire Antenna - Series 1 (802.15.4) - WRL-08665 - SparkFun Electronics)
