Xbee ZigBee Pro (S2C) with Anaren AIR ZigBee
I am working on a scenario where XBee ZigBee Pro (S2C) is a coordinator and Anaren AIR ZigBee (TI CC2530) modules are router/end devices
I am using
-Anaren AIR A2530E24A-LPZ module with MSP430G2
-Xbee ZigBee Pro (S2C) with Raspberry Pi
I was able to communicate between co-ordinator, router and end-devices of AIR A2530E24A-LPZ modules. Also can separately work with Xbee modules. Problem happens when I try to communicate between Xbee and AIR modules.
  1. Does AIR A2530E24A-LPZ support Xbee ZigBee Pro (S2C) module or vice versa? Probably a question for Anaren/Digi but wanted to know your experience.
  2. If I want to use Xbee was the coordinator and A2530E24A-LPZ modules as router/end devices, what network configurations I should be aware off? Channel? PAN ID? What else?
I worked with these TI parts for quite some time, professionally. I gave up. So did Anaren, apparently.
T.I. is sending too much to Bangalore.
