ZED F9P RTK FlOAT
Hello there!
Just have a quick question regarding the out put lights I have read the “setting up a Rover Base RTK System “ tutorials and notice that the zed should not blink (RTK) is the also true for the Ntrip setup? My setup currently dose blink. I had a Lecia cs15 get a rtk fix but now my Carlson surveyor2 will only obtain a rtk float. Just wondering if it’s the zed or my controllers. (I did read somewhere that that Sparky said Carlson is picky just not sure in this sense)
Thank you!
Sixthsantos
The short answer is that, on the ZED-F9P breakout board the RTK LED will be solid on during normal operation, blinking during RTK float and off during RTK fix.
You may be using NTRIP, you might be using other correction sources (radio, etc) but the LED behavior is the same.
Hello Sparky!
I got it to work! For some reason it just won’t get a fix in my yard I walk a little ways away and get the fix. I however have some major accuracy issues… I will open a new post with the results.
Thank you!
Sixthsantos
