agXRP Controller Problems
Does anyone know where I can find the most up to date guide for the agXRP plant growing kit? I found the guides they link but it seems like a lot of information is either out of date or has placeholder information. My biggest issue now is my controller doesn’t show me the default option to control the pump on the main page. Is there a way I can reset the whole board to the default settings to get everything working again? Also the 1st sensor I installed worked great for a few days and now it shows no sensor registered. I even replaced it with a second sensor and it still doesn’t show up. It’s pretty frustrating.
You can try re-flashing the firmware Tutorial 1 — Kit Contents, Assembly & Wiring - AgXRP Setup & User Guide (that links to this MicroPython - Python for microcontrollers ).
The XRP stuff has its own forum where you might have more luck posting there if the above doesn’t help
What sensor? Is it the soil moisture sensor?
