Animal tracking with Argos
Hello friends, I am working on a project related to animal tracking with Argos, now I am analyzing animal positions. Do you have a file like an example of two animals in CSV, XML and KML format to download and analyze?
This https://github.com/sparkfun/SparkFun_AR … no_Library has all of the examples available;
you probably want to check out the guide first https://learn.sparkfun.com/tutorials/ar … 9MQAvD_BwE to get them going, then customize the code/examples for your use-case
Hello, thank you very much for your answer.
What I am looking for is a model file from the Argos company with animal tracks in CSV, TXT format so that I can test in my software. I have a file edited by hand, but I don’t know if it’s right.
Este el el archivo que tengo
prueba1.csv (1.25 KB)
