Bad Link on Website? + Bonus Question
Howdy. I think I found a bad link on the BatchPCB website. Here is what I did:
1)Go to BatchPCB home page
2)Click on “BatchPCB FAQ”
3)Click on “How do I use Eagle?”
  1. Now if you click on any of the following links, it takes me back to the homepage:
“Getting started with Eagle PCB and capturing a schematic”
“The basics of laying out a PCB with Eagle”
“How to create a custom footprint and part in Eagle PCB”
And now for the bonus question:
The reason that I was looking here is because I was wondering If I still have to use silk_gen.ulp or if the silk width is fixed in Eagle 5.2. Also, how do I check what my current silk width is? If someone knows this I would appreciate the knowledge.
You can check the silk width by using the information tool (next to the eye “show” button), or you can right click on it and go properties.
gussy:
I don’t see anything about silk width. I wish I could post an image of what pops up. When I click on text it only gives me the following properties:
Position
Size
Mirror
Spin
Ratio
Font
Layer
Value
However, when I click on a wire it does give me the width property. I am using Eagle 5.2
Venting With Flame:
It’s not broken, so don’t expect it to be fixed.
The problem is/was that EAGLE defaults to 6mil
silk line width which is not compatible with
BatchPCB (GP) tooling.
A wider stroke width for silk screen is recomended
to make the text print visibly and reliably.
The minimum that you can use reliably is 8mil.
Venting With Flame:
Either measure the width of your corrected
silk screen text (layer 121) using the ‘mark’
tool, or draw a new line at 8mil and use that
as a guide (don’t forget to delete this guide
or it will print on your PCB).
