Best time of Day to Survey with RTK Torch? And with PointPerfect MQTT Corrections?
Is there a best, or worst time of day to Survey with your RTK Torch and PointPerfect MQTT Corrections?
The reason I ask is a few days ago (Aug 20th 4pm EDT), I was able to maintain RTK FIX for over an hour straight while I took various averaged points. Then today (Aug 24 5pm EDT to 6:15pm) I was able to get RTK FIX for one 60 pt average, then started a 2nd average made it to 52pt and for the next hour I was never able to get RTK Fix again, went SINGLE, DGPS, RKT Float, but not once for over 60 minutes did it go back to RTK FIX. I tried a Torch REBOOT at about 30 minutes. Tried moving Torch to a location 155ft away. Confirmed over Serial point was receiving Corrections from Point Perfect. Tried boosting Satellite elevation from 18 degrees to 30 degrees (still had 25 satellites in view) Tried boosting Noise to 18db.
This is the testing location in front of my house, which does have trees and some hills, but it’s the inconsistency that is killing me. And spending 80 minutes trying to get one 155ft measurement seems excessive.
Configuration - and some of the Serial port capture below in next messages
minCNO=18
minElev=30
Some Serial Port Output - note it shows getting an IP Address so connected to network and shows Point Perfect as Correction Source….
Rover Accuracy (m): 0.694, SIV: 18 GNSS State: DGPS Fix
18:20:41.835 Pushing 270 bytes from /pp/ip/us topic to PPL for UM980
18:20:41.949 Pushing 1915 bytes from /pp/ip/us topic to PPL for UM980
18:20:42.059 Pushing 1892 bytes from /pp/ip/us topic to PPL for UM980
18:20:42.263 Pushing 1358 bytes from /pp/ip/us topic to PPL for UM980
18:20:42.293 Pushing 236 bytes from /pp/ip/us topic to PPL for UM980
18:20:42.573 Rover Accuracy (m): 0.689, SIV: 18 GNSS State: DGPS Fix
18:20:44.576 Rover Accuracy (m): 0.686, SIV: 18 GNSS State: DGPS Fix
18:20:46.585 Rover Accuracy (m): 0.693, SIV: 18 GNSS State: DGPS Fix
18:20:46.860 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:20:47.039 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:20:47.045 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:20:48.588 Rover Accuracy (m): 0.655, SIV: 18 GNSS State: DGPS Fix
18:20:48.998 WiFi station state: WIFI_STATION_STATE_STABLE, is enabled
18:20:48.998 WiFi Station: 10.77.251.57 (default)
18:20:49.004 WiFi Soft AP: Offline
18:20:49.004 Correction Source: IP (PointPerfect/MQTT)
18:20:50.591 Rover Accuracy (m): 0.669, SIV: 18 GNSS State: DGPS Fix
18:20:51.767 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:20:51.868 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:20:51.868 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:20:52.598 Rover Accuracy (m): 0.667, SIV: 18 GNSS State: DGPS Fix
18:20:54.605 Rover Accuracy (m): 0.663, SIV: 18 GNSS State: DGPS Fix
18:20:56.610 Rover Accuracy (m): 0.664, SIV: 18 GNSS State: DGPS Fix
18:20:56.785 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:20:56.792 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:20:56.895 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:20:58.611 Rover Accuracy (m): 0.668, SIV: 18 GNSS State: DGPS Fix
18:21:00.619 Rover Accuracy (m): 0.687, SIV: 18 GNSS State: DGPS Fix
18:21:01.801 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:21:01.901 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:21:01.901 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:21:02.625 Rover Accuracy (m): 0.690, SIV: 18 GNSS State: DGPS Fix
18:21:04.008 WiFi station state: WIFI_STATION_STATE_STABLE, is enabled
18:21:04.008 WiFi Station: 10.77.251.57 (default)
18:21:04.013 WiFi Soft AP: Offline
18:21:04.013 Correction Source: IP (PointPerfect/MQTT)
18:21:04.626 Rover Accuracy (m): 0.702, SIV: 18 GNSS State: DGPS Fix
18:21:06.627 Rover Accuracy (m): 0.705, SIV: 18 GNSS State: DGPS Fix
18:21:06.819 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:21:06.827 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:21:06.827 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:21:08.632 Rover Accuracy (m): 0.705, SIV: 18 GNSS State: DGPS Fix
18:21:10.637 Rover Accuracy (m): 0.706, SIV: 18 GNSS State: DGPS Fix
18:21:11.847 Pushing 270 bytes from /pp/ip/us topic to PPL for UM980
18:21:11.951 Pushing 1910 bytes from /pp/ip/us topic to PPL for UM980
18:21:12.060 Pushing 1850 bytes from /pp/ip/us topic to PPL for UM980
18:21:12.264 Pushing 1358 bytes from /pp/ip/us topic to PPL for UM980
18:21:12.345 Pushing 236 bytes from /pp/ip/us topic to PPL for UM980
18:21:12.645 Rover Accuracy (m): 0.700, SIV: 18 GNSS State: DGPS Fix
18:21:14.653 Rover Accuracy (m): 0.708, SIV: 18 GNSS State: DGPS Fix
18:21:16.660 Rover Accuracy (m): 0.721, SIV: 18 GNSS State: DGPS Fix
18:21:16.763 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:21:16.944 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:21:16.944 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:21:18.667 Rover Accuracy (m): 0.721, SIV: 18 GNSS State: DGPS Fix
18:21:19.007 WiFi station state: WIFI_STATION_STATE_STABLE, is enabled
18:21:19.007 WiFi Station: 10.77.251.57 (default)
18:21:19.013 WiFi Soft AP: Offline
18:21:19.013 Correction Source: IP (PointPerfect/MQTT)
18:21:20.676 Rover Accuracy (m): 0.725, SIV: 18 GNSS State: DGPS Fix
18:21:21.771 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:21:21.779 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:21:21.874 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:21:22.682 Rover Accuracy (m): 0.791, SIV: 18 GNSS State: DGPS Fix
18:21:24.692 Rover Accuracy (m): 0.802, SIV: 18 GNSS State: DGPS Fix
18:21:26.695 Rover Accuracy (m): 0.819, SIV: 18 GNSS State: DGPS Fix
18:21:26.787 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:21:26.795 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:21:26.795 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:21:28.697 Rover Accuracy (m): 0.831, SIV: 18 GNSS State: DGPS Fix
18:21:30.707 Rover Accuracy (m): 0.842, SIV: 18 GNSS State: DGPS Fix
18:21:31.810 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:21:31.818 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:21:31.818 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:21:32.711 Rover Accuracy (m): 0.844, SIV: 18 GNSS State: DGPS Fix
18:21:34.011 WiFi station state: WIFI_STATION_STATE_STABLE, is enabled
18:21:34.011 WiFi Station: 10.77.251.57 (default)
18:21:34.017 WiFi Soft AP: Offline
18:21:34.017 Correction Source: IP (PointPerfect/MQTT)
18:21:34.719 Rover Accuracy (m): 0.827, SIV: 18 GNSS State: DGPS Fix
18:21:36.728 Rover Accuracy (m): 0.830, SIV: 18 GNSS State: DGPS Fix
18:21:36.840 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:21:36.848 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:21:36.922 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:21:38.733 Rover Accuracy (m): 0.817, SIV: 18 GNSS State: DGPS Fix
18:21:40.741 Rover Accuracy (m): 0.804, SIV: 18 GNSS State: DGPS Fix
18:21:41.949 Pushing 270 bytes from /pp/ip/us topic to PPL for UM980
18:21:41.984 Pushing 1915 bytes from /pp/ip/us topic to PPL for UM980
18:21:42.375 Pushing 1867 bytes from /pp/ip/us topic to PPL for UM980
18:21:42.468 Pushing 1359 bytes from /pp/ip/us topic to PPL for UM980
18:21:42.556 Pushing 236 bytes from /pp/ip/us topic to PPL for UM980
18:21:42.746 Rover Accuracy (m): 0.797, SIV: 18 GNSS State: DGPS Fix
18:21:44.754 Rover Accuracy (m): 0.787, SIV: 18 GNSS State: DGPS Fix
18:21:46.762 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:21:46.942 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:21:46.942 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:21:47.151 Rover Accuracy (m): 0.775, SIV: 18 GNSS State: DGPS Fix
18:21:49.020 WiFi station state: WIFI_STATION_STATE_STABLE, is enabled
18:21:49.020 WiFi Station: 10.77.251.57 (default)
18:21:49.026 WiFi Soft AP: Offline
18:21:49.026 Correction Source: IP (PointPerfect/MQTT)
18:21:49.157 Rover Accuracy (m): 0.713, SIV: 18 GNSS State: DGPS Fix
18:21:51.166 Rover Accuracy (m): 0.711, SIV: 18 GNSS State: DGPS Fix
18:21:51.882 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:21:51.892 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:21:51.916 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:21:53.171 Rover Accuracy (m): 0.709, SIV: 18 GNSS State: DGPS Fix
18:21:55.177 Rover Accuracy (m): 0.696, SIV: 18 GNSS State: DGPS Fix
18:21:56.897 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:21:56.905 Pushing 37 bytes from /pp/ip/us topic to PPL for UM980
18:21:56.905 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:21:57.184 Rover Accuracy (m): 0.715, SIV: 18 GNSS State: DGPS Fix
18:21:59.191 Rover Accuracy (m): 0.710, SIV: 18 GNSS State: DGPS Fix
18:22:01.195 Rover Accuracy (m): 0.715, SIV: 18 GNSS State: DGPS Fix
18:22:01.813 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:22:01.821 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:22:01.821 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:22:03.203 Rover Accuracy (m): 0.707, SIV: 18 GNSS State: DGPS Fix
18:22:04.026 WiFi station state: WIFI_STATION_STATE_STABLE, is enabled
18:22:04.026 WiFi Station: 10.77.251.57 (default)
18:22:04.032 WiFi Soft AP: Offline
18:22:04.032 Correction Source: IP (PointPerfect/MQTT)
18:22:05.209 Rover Accuracy (m): 0.706, SIV: 18 GNSS State: DGPS Fix
18:22:06.827 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:22:06.835 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:22:06.835 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:22:07.213 Rover Accuracy (m): 0.703, SIV: 18 GNSS State: DGPS Fix
18:22:09.219 Rover Accuracy (m): 0.697, SIV: 18 GNSS State: DGPS Fix
18:22:11.224 Rover Accuracy (m): 0.705, SIV: 18 GNSS State: DGPS Fix
18:22:11.743 Pushing 270 bytes from /pp/ip/us topic to PPL for UM980
18:22:11.857 Pushing 1920 bytes from /pp/ip/us topic to PPL for UM980
18:22:11.979 Pushing 1914 bytes from /pp/ip/us topic to PPL for UM980
18:22:12.182 Pushing 1359 bytes from /pp/ip/us topic to PPL for UM980
18:22:12.258 Pushing 236 bytes from /pp/ip/us topic to PPL for UM980
18:22:13.229 Rover Accuracy (m): 0.705, SIV: 18 GNSS State: DGPS Fix
18:22:15.232 Rover Accuracy (m): 0.707, SIV: 18 GNSS State: DGPS Fix
18:22:16.761 Pushing 50 bytes from /pp/ip/us topic to PPL for UM980
18:22:16.943 Pushing 34 bytes from /pp/ip/us topic to PPL for UM980
18:22:16.943 Pushing 31 bytes from /pp/ip/us topic to PPL for UM980
18:22:17.233 Rover Accuracy (m): 0.699, SIV: 18 GNSS State: DGPS Fix
18:22:19.030 WiFi station state: WIFI_STATION_STATE_STABLE, is enabled
18:22:19.030 WiFi Station: 10.77.251.57 (default)
18:22:19.035 WiFi Soft AP: Offline
18:22:19.035 Correction Source: IP (PointPerfect/MQTT)
18:22:19.239 Rover Accuracy (m): 0.686, SIV: 18 GNSS State: DGPS Fix
18:22:21.247 Rover Accuracy (m): 0.705, SIV: 18 GNSS State: DGPS Fix
18:22:21.791 Pushing 106 bytes from /pp/ip/us topic to PPL for UM980
18:22:23.249 Rover Accuracy (m): 0.724, SIV: 18 GNSS State: DGPS Fix
Profile Printout
Menu: User Profiles
  1. Select PPerfectTiltOFF ← Current
  2. Select (Empty)
  3. Select (Empty)
  4. Select (Empty)
  5. Select (Empty)
  6. Select (Empty)
  7. Select (Empty)
  8. Select (Empty)
  9. Edit profile name: PPerfectTiltOFF
  10. Set profile ‘PPerfectTiltOFF’ to factory defaults
  11. Delete profile ‘PPerfectTiltOFF’
  12. Print profile
    x) Exit
    12
    Select the profile to be printed (1-8): 1
sizeOfSettings=4000
rtkIdentifier=34
antennaHeight_mm=0
antennaPhaseCenter_mm=116.50
coordinateInputType=0
fixedAltitude=1560.0890
fixedBase=0
fixedBaseCoordinateType=0
fixedEcefX=-1280206.568
fixedEcefY=-4716804.403
fixedEcefZ=4086665.484
fixedLat=40.090294790
fixedLong=-105.185057610
observationSeconds=60
observationPositionAccuracy=5.00
surveyInStartingAccuracy=2.0
enablePrintBatteryMessages=0
shutdownNoChargeTimeoutMinutes=0
enableBeeper=1
bluetoothRadioType=2
sppRxQueueSize=2048
sppTxQueueSize=32
correctionsSourcesLifetime=30
correctionsPriority_External Radio=3
correctionsPriority_ESP-Now=4
correctionsPriority_LoRa Radio=5
correctionsPriority_Bluetooth=2
correctionsPriority_USB Serial=6
correctionsPriority_TCP (NTRIP)=1
correctionsPriority_L-Band=7
correctionsPriority_IP (PointPerfect/MQTT)=0
debugCorrections=0
debugEspNow=0
enableEspNow=0
espnowPeerCount=0
espnowPeer_0=00:00:00:00:00:00,
espnowPeer_1=00:00:00:00:00:00,
espnowPeer_2=00:00:00:00:00:00,
espnowPeer_3=00:00:00:00:00:00,
espnowPeer_4=00:00:00:00:00:00,
autoFirmwareCheckMinutes=1440
debugFirmwareUpdate=0
enableAutoFirmwareUpdate=0
serialGNSSRxFullThreshold=50
uartReceiveBufferSize=2048
debugGnss=0
enablePrintPosition=0
measurementRateMs=1000
navigationRate=1
gnssConfiguredOnce=1
gnssConfiguredBase=0
gnssConfiguredRover=0
debugHttpClientData=0
debugHttpClientState=0
debugMqttClientData=1
debugMqttClientState=1
mdnsEnable=1
mdnsHostName=rtk
debugNetworkLayer=0
printNetworkStatus=1
debugNtripClientRtcm=0
debugNtripClientState=0
enableNtripClient=0
ntripClientCasterHost=rtk2go.com
ntripClientCasterPort=2101
ntripClientCasterUser=test@test.com
ntripClientCasterUserPW=
ntripClientMountPoint=bldr_SparkFun1
ntripClientMountPointPW=
ntripClientTransmitGGA=1
debugNtripServerRtcm=0
debugNtripServerState=0
enableNtripServer=0
enableRtcmMessageChecking=0
ntripServerCasterHost_0=rtk2go.com
ntripServerCasterHost_1=
ntripServerCasterHost_2=
ntripServerCasterHost_3=
ntripServerCasterPort_0=2101
ntripServerCasterPort_1=2101
ntripServerCasterPort_2=2101
ntripServerCasterPort_3=2101
ntripServerCasterUser_0=test@test.com
ntripServerCasterUser_1=
ntripServerCasterUser_2=
ntripServerCasterUser_3=
ntripServerCasterUserPW_0=
ntripServerCasterUserPW_1=
ntripServerCasterUserPW_2=
ntripServerCasterUserPW_3=
ntripServerMountPoint_0=bldr_dwntwn2
ntripServerMountPoint_1=
ntripServerMountPoint_2=
ntripServerMountPoint_3=
ntripServerMountPointPW_0=WR5wRo4H
ntripServerMountPointPW_1=
ntripServerMountPointPW_2=
ntripServerMountPointPW_3=
bluetoothInterruptsCore=1
btReadTaskCore=1
btReadTaskPriority=1
debugMalloc=0
enableHeapReport=0
enablePrintIdleTime=0
enablePsram=1
enableTaskReports=0
gnssReadTaskCore=1
gnssReadTaskPriority=1
gnssUartInterruptsCore=1
handleGnssDataTaskCore=1
handleGnssDataTaskPriority=1
i2cInterruptsCore=1
measurementScale=0
printBootTimes=0
printPartitionTable=0
printTaskStartStop=0
psramMallocLevel=40
rebootMinutes=0
resetCount=0
periodicDisplay=137975824388
periodicDisplayInterval=15000
autoKeyRenewal=1
debugPpCertificate=0
geographicRegion=0
lastKeyAttempt=1756073437
lbandFixTimeout=180
pointPerfectBrokerHost=pp.services.u-blox.com
pointPerfectClientID=
pointPerfectCurrentKey=
pointPerfectCurrentKeyDuration=2419199999
pointPerfectCurrentKeyStart=1755647982000
pointPerfectDeviceProfileToken=
pointPerfectKeyDistributionTopic=/pp/ubx/0236/ip
pointPerfectNextKey=
pointPerfectNextKeyDuration=2419199999
pointPerfectNextKeyStart=1758067182000
pplFixTimeoutS=180
regionalCorrectionTopics_0=/pp/ip/us
regionalCorrectionTopics_1=/pp/ip/eu
regionalCorrectionTopics_2=
regionalCorrectionTopics_3=/pp/ip/kr
regionalCorrectionTopics_4=
pointPerfectService=5
profileName=PPerfectTiltOFF
enablePrintRingBufferOffsets=0
gnssHandlerBufferSize=4096
dynamicModel=0
enablePrintRoverAccuracy=1
minCNO=18
minElev=30
enablePrintRtcSync=0
dataPortBaud=115200
echoUserInput=1
enableGnssToUsbSerial=0
radioPortBaud=57600
serialTimeoutGNSS=1
disableSetupButton=0
enablePrintDuplicateStates=0
enablePrintStates=1
lastState=0
debugTcpClient=1
enableTcpClient=0
tcpClientHost=
tcpClientPort=2948
debugTcpServer=0
enableTcpServer=0
tcpServerPort=2948
tcpUdpOverWiFiStation=1
timeZoneHours=0
timeZoneMinutes=0
timeZoneSeconds=0
debugUdpServer=0
enableUdpServer=0
udpServerPort=10110
enableGalileoHas=0
enableImuCompensationDebug=0
enableImuDebug=0
enableTiltCompensation=0
constellation_BeiDou=1
constellation_Galileo=1
constellation_GLONASS=1
constellation_GPS=1
constellation_QZSS=0
messageRateNMEA_GPDTM=0.00
messageRateNMEA_GPGBS=0.00
messageRateNMEA_GPGGA=1.00
messageRateNMEA_GPGLL=0.00
messageRateNMEA_GPGNS=0.00
messageRateNMEA_GPGRS=0.00
messageRateNMEA_GPGSA=1.00
messageRateNMEA_GPGST=1.00
messageRateNMEA_GPGSV=1.00
messageRateNMEA_GPRMC=1.00
messageRateNMEA_GPROT=0.00
messageRateNMEA_GPTHS=0.00
messageRateNMEA_GPVTG=0.00
messageRateNMEA_GPZDA=0.00
messageRateRTCMBase_RTCM1001=0.00
messageRateRTCMBase_RTCM1002=0.00
messageRateRTCMBase_RTCM1003=0.00
messageRateRTCMBase_RTCM1004=0.00
messageRateRTCMBase_RTCM1005=1.00
messageRateRTCMBase_RTCM1006=0.00
messageRateRTCMBase_RTCM1007=0.00
messageRateRTCMBase_RTCM1009=0.00
messageRateRTCMBase_RTCM1010=0.00
messageRateRTCMBase_RTCM1011=0.00
messageRateRTCMBase_RTCM1012=0.00
messageRateRTCMBase_RTCM1013=0.00
messageRateRTCMBase_RTCM1019=0.00
messageRateRTCMBase_RTCM1020=0.00
messageRateRTCMBase_RTCM1033=10.00
messageRateRTCMBase_RTCM1042=0.00
messageRateRTCMBase_RTCM1044=0.00
messageRateRTCMBase_RTCM1045=0.00
messageRateRTCMBase_RTCM1046=0.00
messageRateRTCMBase_RTCM1071=0.00
messageRateRTCMBase_RTCM1072=0.00
messageRateRTCMBase_RTCM1073=0.00
messageRateRTCMBase_RTCM1074=1.00
messageRateRTCMBase_RTCM1075=0.00
messageRateRTCMBase_RTCM1076=0.00
messageRateRTCMBase_RTCM1077=0.00
messageRateRTCMBase_RTCM1081=0.00
messageRateRTCMBase_RTCM1082=0.00
messageRateRTCMBase_RTCM1083=0.00
messageRateRTCMBase_RTCM1084=1.00
messageRateRTCMBase_RTCM1085=0.00
messageRateRTCMBase_RTCM1086=0.00
messageRateRTCMBase_RTCM1087=0.00
messageRateRTCMBase_RTCM1091=0.00
messageRateRTCMBase_RTCM1092=0.00
messageRateRTCMBase_RTCM1093=0.00
messageRateRTCMBase_RTCM1094=1.00
messageRateRTCMBase_RTCM1095=0.00
messageRateRTCMBase_RTCM1096=0.00
messageRateRTCMBase_RTCM1097=0.00
messageRateRTCMBase_RTCM1104=0.00
messageRateRTCMBase_RTCM1111=0.00
messageRateRTCMBase_RTCM1112=0.00
messageRateRTCMBase_RTCM1113=0.00
messageRateRTCMBase_RTCM1114=0.00
messageRateRTCMBase_RTCM1115=0.00
messageRateRTCMBase_RTCM1116=0.00
messageRateRTCMBase_RTCM1117=0.00
messageRateRTCMBase_RTCM1121=0.00
messageRateRTCMBase_RTCM1122=0.00
messageRateRTCMBase_RTCM1123=0.00
messageRateRTCMBase_RTCM1124=1.00
messageRateRTCMBase_RTCM1125=0.00
messageRateRTCMBase_RTCM1126=0.00
messageRateRTCMBase_RTCM1127=0.00
messageRateRTCMRover_RTCM1001=0.00
messageRateRTCMRover_RTCM1002=0.00
messageRateRTCMRover_RTCM1003=0.00
messageRateRTCMRover_RTCM1004=0.00
messageRateRTCMRover_RTCM1005=0.00
messageRateRTCMRover_RTCM1006=0.00
messageRateRTCMRover_RTCM1007=0.00
messageRateRTCMRover_RTCM1009=0.00
messageRateRTCMRover_RTCM1010=0.00
messageRateRTCMRover_RTCM1011=0.00
messageRateRTCMRover_RTCM1012=0.00
messageRateRTCMRover_RTCM1013=0.00
messageRateRTCMRover_RTCM1019=0.00
messageRateRTCMRover_RTCM1020=0.00
messageRateRTCMRover_RTCM1033=0.00
messageRateRTCMRover_RTCM1042=0.00
messageRateRTCMRover_RTCM1044=0.00
messageRateRTCMRover_RTCM1045=0.00
messageRateRTCMRover_RTCM1046=0.00
messageRateRTCMRover_RTCM1071=0.00
messageRateRTCMRover_RTCM1072=0.00
messageRateRTCMRover_RTCM1073=0.00
messageRateRTCMRover_RTCM1074=0.00
messageRateRTCMRover_RTCM1075=0.00
messageRateRTCMRover_RTCM1076=0.00
messageRateRTCMRover_RTCM1077=0.00
messageRateRTCMRover_RTCM1081=0.00
messageRateRTCMRover_RTCM1082=0.00
messageRateRTCMRover_RTCM1083=0.00
messageRateRTCMRover_RTCM1084=0.00
messageRateRTCMRover_RTCM1085=0.00
messageRateRTCMRover_RTCM1086=0.00
messageRateRTCMRover_RTCM1087=0.00
messageRateRTCMRover_RTCM1091=0.00
messageRateRTCMRover_RTCM1092=0.00
messageRateRTCMRover_RTCM1093=0.00
messageRateRTCMRover_RTCM1094=0.00
messageRateRTCMRover_RTCM1095=0.00
messageRateRTCMRover_RTCM1096=0.00
messageRateRTCMRover_RTCM1097=0.00
messageRateRTCMRover_RTCM1104=0.00
messageRateRTCMRover_RTCM1111=0.00
messageRateRTCMRover_RTCM1112=0.00
messageRateRTCMRover_RTCM1113=0.00
messageRateRTCMRover_RTCM1114=0.00
messageRateRTCMRover_RTCM1115=0.00
messageRateRTCMRover_RTCM1116=0.00
messageRateRTCMRover_RTCM1117=0.00
messageRateRTCMRover_RTCM1121=0.00
messageRateRTCMRover_RTCM1122=0.00
messageRateRTCMRover_RTCM1123=0.00
messageRateRTCMRover_RTCM1124=0.00
messageRateRTCMRover_RTCM1125=0.00
messageRateRTCMRover_RTCM1126=0.00
messageRateRTCMRover_RTCM1127=0.00
httpPort=80
debugWebServer=0
debugWifiState=1
enableCaptivePortal=1
wifiChannel=1
wifiConfigOverAP=0
wifiNetwork_0SSID=
wifiNetwork_0Password=
wifiNetwork_1SSID=
wifiNetwork_1Password=
wifiNetwork_2SSID=
wifiNetwork_2Password=
wifiNetwork_3SSID=
wifiNetwork_3Password=
wifiConnectTimeoutMs=20000
outputTipAltitude=327680
useLocalizedDistribution=0
localizedDistributionTileLevel=5
useAssistNow=0
requestKeyUpdate=0
enableLora=0
loraCoordinationFrequency=910.000
debugLora=0
loraSerialInteractionTimeout_s=30
enableMultipathMitigation=1
debugSettings=0
enableNtripCaster=0
baseCasterOverride=0
rtkFirmwareVersion=v2.2
gnssFirmwareVersion=11833
gnssUniqueId=ff3bd4976a7d169b
otaRcFirmwareJsonUrl=
otaFirmwareJsonUrl=
Hi Chris,
It looks like you are using the continental PointPerfect corrections topic. Maybe give the localized corrections a try?
Interesting… so as I went searching for that configuration option, I noticed my Source Correction Lifetime changed from 60 seconds back to 30 seconds….
And for Point Perfect I had set it to USE Localized, and that was set back to Disabled. (don’t know why)
and my Tile LEVEL was back to 250x250 high Density, I was previously testing with 500kmx500km High Density.
When I start having trouble I will check to see if those settings didn’t save. I didn’t do a factory reset, as profiles were there and other things like Satellite elevation had not changed. Unfortunately I may not be able to test until Thursday, but I will test in a few days…. very odd as I have been very careful on settings changes as I have struggled to get consistent results due to my challenging conditions (Trees, mountains, valleys, ignorance)
