Hello, I would like to know a basic pin connection to the sparkfun bluetooth module, it looks it doesn’t have a pin out connection in data paper, or what are the correct pin numbers
thank you in advance
anyone?.. a basic pin-out connection to the bluetooth sparkfun module? or where are the vcc,gnd and tx,rx…
greetings
There are several bluetooth modules which one?
http://www.sparkfun.com/datasheets/RF/B … Ant-v1.pdf
http://www.sparkfun.com/datasheets/Wire … heet-1.pdf
http://www.rovingnetworks.com/documents/RN-41.pdf
Page down on the modules description you will see links for its pin outs.
