WRL-08474 Packaging
I’m looking at using the [WRL-08474 bluetooth SMD module but I cannot find the complete pinout. The [schematic has a part called FP that looks like the connector, but I see no way to correlate the pins numbers in the schematic with the pin numbers in the [dimensional drawing.
Does anyone have the data that ties the pin numbers to the pad locations?
Thanks.](http://www.sparkfun.com/datasheets/Wireless/Bluetooth/sfe_bluetooth_module_16vii08.pdf)](http://www.sparkfun.com/datasheets/Wireless/Bluetooth/SparkFun-Bluetooth-v23.pdf)](http://www.sparkfun.com/commerce/product_info.php?products_id=8474)
I have the same problem.
Please update the product-page with more information about the pin-numbering…
By inspecting my module, I’ve been able to deduce that the pins are numbered 1 through 12 down one side, then 13 through 24 on the other side, with 25-29 referring to various ground or N/C pads. Pins 1 and 24 are on the end near the long white antenna.
