So as the title says, I bought the ESP32 Pro Mini on a whim to fill the last $9 to free shipping. Smart, no… but I was interested in trying the ESP32 for a weather station project I had intended on doing sooner or later. Fast forward to now, opened it up and started looking at the hardware hookup guide and the guide says “To follow along with this tutorial, you will need the following materials. You may not need everything though depending on what you have. Add it to your cart, read through the guide, and adjust the cart as necessary.” That guide shows the “SparkFun Serial Basic Breakout - CH340C and USB-C” and an accompanying USB-C cable. Is the CH340 necessary for the programming or can I utilize a GPIO wiring method?
The guide seems to allude that there might be an alternative, so it got me searching on the forum before posting and I cannot find anything that specifies an alternative. So with that I’ll guess that I do actually need a CH340 breakout to get this “working” and then disconnect it when I finish programming to utilize in the project while powering from GPIO. Correct?
