Can someone with Electra help me out?
I need one board routed. Electra routs it in the blink of an eye, but Eagle takes forever and leaves 50 air wires. I can send the dsn file, and I would be happy to make a donation to the charity of your choice as a thank you.
I could import your Eagle board file into Pulsonix, route it with Electra, and send you the Gerbers etc. You won’t be able to import the routed board back into Eagle, of course, but you will be able to view the file with the Pulsonix demo software.
Hi Leon, thanks very much, that’s very nice of you. I’m not sure this will help after all. The issue I am having is that there are a bunch of polygon islands sort of, on the GND signal and I can’t gt them hooked up. I emailed Electra support, and they said Electra won’t auto route those. So I may still need to hand edit it after it is auto routed.
