COM-10969 lead diameter size
Hello, I would like to know what the lead diameter is for this resistor pack. I need to use it on breadboard. COM-10969
THanks,
Majid
It’s a pack containing a variety of sizes, the leads vary by their obligate resistor size…do you prefer them to be longer or shorter, thicker or skinnier? Are you having any issues?
If you have some/one in-hand I’d hazard a guess a set of calipers & measurements would be better than going by the documents
Ostensibly with a breadboard you’d be able to adjust & bend the legs however you need to and simply insert. If you do require strict measurements let me know and we’ll get those going
You should have no issues using these in a breadboard. :grinning_face:
Hello, Thank you for your response. Could you please let me know the lead diameter of the resistors included in this resistor pack?
Hello Russell, Thank you for your response. Could you please let me know the lead diameter of the resistors included in this resistor pack?
No idea, I don’t have any with me at this time to measure. I
do have some somewhere in my workshop and have used them in breadboards so i can verify you’re ok to use them in a breadboard.
I don’t recall the lead diameter looking any different than any other 1/4 watt resistor though.
We measured some today and they are 0.33-0.35mm thick, so right around ~0.34mm on average
Hello Russell, Thank you for confirming. Do you have any other 0.25 W resistor packs with lead diameters between 0.45 mm and 0.65 mm?
Majid
We do not presently :-/
