You should be able to just connect the (correctly configured) OpenLog to the GPS, and it will log everything. That probably is not the most desirable way to proceed, though, as most of the data won’t be useful.
Sparkfun has posted an extensive tutorial on using OpenLog, and I suggest that you work your way through it.
