dimensions of SparkFun Atmospheric Sensor Breakout - BME280
this is my first post, so hello to everybody.
I want to 3D print an enclosure for a SparkFun Atmospheric Sensor Breakout - BME280, but I can’t find anywhere the dimensions of this board, e.g. the distance between the holes on the pcb. Any help is appreciated.
On the product listing page, select the Documents tab and then Eagle Files. Download and unzip that. Then you need to use some program that can open/import Eagle CAD files. I have used [KiCad in the past for doing the same thing. It should have some sort of measurement tool you can use.](https://www.kicad.org/)
