Diode specs for Pro Micro
I’m building a PCB that is based on the Sparkfun pro micro. The schematic identifies it as a SOD-323.
Would this be suitable:
SWITCHING DIODE 100V 150MA 1.25V @ 150MA 4NS SOD-323 ROHS
If not - what are the pertinent specs I should be looking for?
thanks!
Damon
Hello Damon.
A Schottky diode would be preferred in this application so that you don’t burn up a bunch of voltage through the diode but any diode would work as long as it’s rated for the voltage and current you expect to use.
Hi Chris,
Thanks for the info!
Damon
