EAGLE CADSOFT
does any one have a serial or liscense for eagle 4.16r2? i can’t make a larger board because im only using a freeware… tnx!
Why don’t you do like everyone that has the license and pay for it? Asking others to commit a crime wont get you far…
Buy the $125 non-profit license. Unless you’re starting a company, this will be just fine.
It gives you 160x100mm board size and up to 4 layers.
http://www.cadsoftusa.com/nonprofit.htm
Technically you can make larger boards, you just have to choose and hand-place all the packages and hand-route (using the line tool, not the wire/route tool) everything. No nets, no schematics, just lines and packages. I’ve done it before, but that was several years ago so they may have changed the software. I don’t know. Try it and see what happens.
Andrew02E:
They have. You can’t even make a board 4" tall x 3" wide. It must be 4" wide x 3" tall and no bigger. Placing anything outside of this invisible boundary results in a nice error dialog box.
