my question is how do i create a solder pad with holes in it? do i just draw a rectangle in the top layer and then place the holes, does it matter if the holes and rectangle overlap?
What I usually do for that, is I create a square via, then finish it off (increase length, etc) with rectangles. That way you have a copper-free hole in the middle surrounded by whatever copper pad shape you need. Might be a slightly inefficient way to do it, but it works for me. Rough example:
thanks! that should work. one question though, aren’t vias plated? i thought only “holes” were copper free? not that it matters because it’s not an electrical part, just wondering.
