Facet L-Band Direct v4.1 - Error: PointPerfect corrections currently supported by ZED-F9P firmware v1.30 and above
Hi
I just received my RTK Facet L-Band and I am not getting L-Band corrections.
Error: PointPerfect corrections currently supported by ZED-F9P firmware v1.30 and above.
The serial console shows this unit is running ZED-F9P firmware: HPG 1.13
Do i really need to slog through this process to get L-Band corrections working ?
https://learn.sparkfun.com/tutorials/how-to-upgrade-firmware-of-a-u-blox-gnss-receiver
r
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1240
load:0x40078000,len:13012
load:0x40080400,len:3648
entry 0x400805f8
0x36 - MAX17048 Fuel Gauge
0x3d - SSD1306 (64x48) OLED Driver
0x42 - u-blox ZED-F9P GNSS Receiver
0x43 - u-blox NEO-D9S-00B Correction Data Receiver
Display started
LittleFS Started
SparkFun RTK Facet L-Band Direct v4.1
Profile ‘foofoo’ loaded
Fuel gauge configuration complete
Batt (90%): Voltage: 4.11V Charging: 3.95%/hr Green
GNSS configuration complete
NEO-D9S firmware: PMP 1.04
Setting L-Band frequency to US (1556290000Hz)
L-Band online
System time set to: Monday, October 21 2024 18:40:51
STATE_KEYS_STARTED → STATE_KEYS_DAYS_REMAINING, 2024-10-21 18:40:52.232
Days until PointPerfect keys expire: 55
STATE_KEYS_DAYS_REMAINING → STATE_KEYS_LBAND_CONFIGURE, 2024-10-21 18:40:54.36 1
Please upgrade your ZED firmware: How to Upgrade Firmware of a u-blox GNSS Receiver - SparkFun Learn
STATE_KEYS_LBAND_CONFIGURE → STATE_ROVER_NOT_STARTED, 2024-10-21 18:40:54.843
networkStop called by /home/runner/work/SparkFun_RTK_Firmware/SparkFun_RTK_Firmware/Firmware/RTK_Surveyor/States.ino 124
wifiStop called by /home/runner/work/SparkFun_RTK_Firmware/SparkFun_RTK_Firmware/Firmware/RTK_Surveyor/States.ino 125
Web Server Stopped
networkStop called by /home/runner/work/SparkFun_RTK_Firmware/SparkFun_RTK_Firmware/Firmware/RTK_Surveyor/WiFi.ino 429
Bluetooth SPP broadcasting as: Facet L-Band Direct Rover-5DF6
STATE_ROVER_NOT_STARTED → STATE_ROVER_NO_FIX, 2024-10-21 18:40:56.367
STATE_ROVER_NO_FIX → STATE_ROVER_FIX, 2024-10-21 18:40:56.475
Rover Accuracy (m): 2.4114, SIV: 24
Rover Accuracy (m): 2.3759, SIV: 24
Rover Accuracy (m): 2.3459, SIV: 24
*WIFI_STATE_OFF
Rover Accuracy (m): 2.3183, SIV: 24
Rover Accuracy (m): 2.2974, SIV: 23
Rover Accuracy (m): 2.2778, SIV: 23
Rover Accuracy (m): 2.2601, SIV: 23
Rover Accuracy (m): 2.2515, SIV: 25
Rover Accuracy (m): 2.2435, SIV: 24
Rover Accuracy (m): 2.2368, SIV: 23
*WIFI_STATE_OFF
Rover Accuracy (m): 2.2330, SIV: 24
Rover Accuracy (m): 2.2288, SIV: 24
Rover Accuracy (m): 2.2242, SIV: 24
** Bluetooth SPP broadcasting as: Facet L-Band Direct Rover-5DF6 **
Menu: Main
  1. Configure GNSS Receiver
  2. Configure GNSS Messages
  3. Configure Base
  4. Configure Ports
  5. Configure Logging
  6. Configure WiFi
  7. Configure Network
    p) Configure User Profiles
    r) Configure Radios
    P) Configure PointPerfect
    s) Configure System
    f) Firmware upgrade
    x) Exit
HPG 1.13 is over 4 years old, it doesn’t understand SPARTN/L-BAND format data.
You need at least HPG 1.30 to support SPARTN v2.01
