has anyone connected the FS3000 Sensor via mqtt to home assistant ? Ineed help with my code.
Thanks in advance
Florian
Thanks in advance
Florian
I don’t have much to offer, but maybe take a look here https://community.home-assistant.io/t/u … qtt/341189 for some common mistakes during integration, and poke around their official docs here https://www.home-assistant.io/integrations/sensor.mqtt/ for more info on getting it set up
Thank you for your help, but i can’t get it to work. I’m fairly new to the whole programming, so this might be my main issue
This is my usual approach to these types of things: Try focusing on getting good readings from the sensor, then test some default MQTT messages, then try to combine the 2 into one ![]()
is it possible to use the esphome integration in home assistant to get the sensor values on home assistant ?
