There seems to be a red ‘heartbeat’ indicator on my new Garmin LIDAR-Lite V4/LED unit, but I can’t find any references to it in the docs. Anyone else see this?
It’s just the Power LED we added to the unit; if it’s bothersome you can disable it by de-soldering/cutting separating the pads mentioned in the ‘jumpers’ section here https://learn.sparkfun.com/tutorials/ga … e-overview
I received this from the Garmin support folks:
"Hello Frank,
The red light inside the sensor is exactly what you suspected. It’s an activity indicator lamp. It shows that the internal processor is running. "
