I recently received the “GeoChron - Field-hardened GPS Logger”. It works as expected with one exception.
When only recording RMC sentence (Mode 1) the line endings in the log file are messed up. They are only contain a CR character (0D in hex) when they should be a CR+LF (assuming you want dos format). When I change the glogcon.txt file to record both RMC and GGA, all of the lines on the log files have the proper line endings (CR+LF).
Below is the configuration that causes the problem on my unit:
Mode = 1
Log What = RMC
Time Between Logs = 00:01:00
Holdoff = 10
WAAS = 1
This is repeatable.
Has anyone else seen this?
Best Regards,
- Gerry
