I want to use the GPS-19633 with it’s ZED-F9P-02B with U-center. Is is capable of doing this? Do I connect via the USB-C directly to U-blox U-Center or is other software or hardware required?
Thanks in advance
Greg
Thanks in advance
Greg
That version/board requires an additional carrier board (like https://www.sparkfun.com/products/18575); you could instead use https://www.sparkfun.com/products/16481 and interface with u-center over USB easily https://learn.sparkfun.com/tutorials/gp … e-overview as a standalone (with a compatible antenna and a clear view of the sky!)
I’m interested in the ZED-F9P-02B which is part of the GPS-19633. The GPS-16481 product photo apparently shows the older ZED-F9P-00B. Can you confirm the the 16481 has the ZED-F9P-00B or the newer ZED-F9P-02B?
Also, the datasheet in the page for the GPS-16481 links to a ZED-F9P-02B data sheet. Is the photo perhaps incorrect?
We’re shipping 02B
Product photos are always tricky to keep current; just FYI the only difference in the 00B vs 02B etc is the firmware revision; a 00B can be turned into a 02B easily via u-blox’s firmware uploader
