So… I’ve got this header baord from olimex: http://www.olimex.com/dev/index.html (AVR-H128C)
It says "WITH STKxxx COMPATIBLE 10 PIN ICSP CONNECTOR".
So, i hook up my STK500, make a quick easy program using the STK’s LED’s, hook up the header board to the ‘ISP10PIN’ socket, compile it, and load it…
… it does nothing.
I’ve made sure that the right pins from the AVR go to the LED’s. THe STK500 seems to recognise that it has found a ATmega128.
Do i need to power the header board? THe schematic for the ISP10PIN makes me think power is supplied via the ISP socket ( http://www.olimex.com/dev/images/avr-icsp-10.gif )
If so, is there a pin on the stk500 to supply +5v?
The manual for both the STK500 and this Omimex headboard don’t tell me anything?
