Hi, this is probably simplest PCB you will ever see.
I have a part that has SMD pads which needs to be routed into an easier to work with through hole connections. So I figured I’d just make a PCB that does that (maybe there is an easier way? the SMD pads have nonstandard spacing though)
When I run the design rule check , I get errors that indicates “Stop Mask” where the SMD pads are. What could be the problem? Screenshot is attached, thanks.
Hi, I figured out what the problem was. I outlined the component using a silk screen layer so once I switched to some harmless layer than the error went away.
