Is it possible to all in one transformers plugged into one strips?
Hello, [PartyCityFeedback
I have a cabinet that charges handheld LED lights. I think I can charge 12 to 15 devices. I have a 3 surge strips that have 15 transformers plugged into them. There is a lot of wires. What I was looking for is a product that is one device that I can charge 5 devices on. They use a barrel type connector. I guess 12v5A ac/dc transformer is needed for each one. So, I am looking for one device that I can attach cables to that has the power to charge once. Is it possible to all in one transformers plugged into one strips? Need help. Any help would be appreciated.](Official PartyCityFeedback - Take Survey & Win PartyCity Coupons)
We need more information.
What are you charging?
What voltage and current do the devices require?
Guesses won’t work for this, if you guess wrong all your devices could be damaged or even worse, catch fire.
If the devices have their own charging provisions and simply need 12 VDC (or whatever) to charge themselves, you can probably use a single, higher-capacity power supply with the devices in parallel.
This sort of thing could help: https://www.delock.com/produkt/83288/merkmale.html
