Issue with AT&T SIM Card Registration on SARA-R410M LTE Module
I am currently utilizing the SparkFun LTE CAT M1/NB-IoT Shield - SARA-R4 for my research project. Until now, I have successfully used a Hologram SIM card with this module without any issues. However, I’ve recently encountered a problem when attempting to use an AT&T SIM card in LTE mode.
After registering the AT&T SIM with the LTE module, the NET blue light turns solid, indicating successful data transmission capability. However, if I power off the device and later power it back on, the LTE module fails to automatically reconnect to the network, and the NET light does not turn blue. I need to go through the registration process again.
This issue does not occur with the Hologram SIM card; with it, I register the module once, and then the device reconnects to the network automatically upon powering up when it is used later on, and the NET light turns ON immediately. I expect the same behavior with ATT SIM.
NOTE: I am using an ATT Business SIM card. I set APN to “Broadband” for ATT and network operator to MNO_ATT
LTE Module Model: SARA-R410M
Can anyone suggest to me what might be the issue?
My code:
Register your LTE Shield/SIM combo on a mobile network operator
By: Jim Lindblom
SparkFun Electronics
Date: November 19, 2018
License: This code is public domain but you buy me a beer if you use this
and we meet someday (Beerware license).
Feel like supporting our work? Buy a board from SparkFun!
https://www.sparkfun.com/products/14997
This example demonstrates how to initialize your Cat M1/NB-IoT shield, and
connect it to a mobile network operator (Verizon, AT&T, T-Mobile, etc.).
Before beginning, you may need to adjust the mobile network operator (MNO)
setting on line 45. See comments above that line to help select either
Verizon, T-Mobile, AT&T or others.
You may also need to set an APN on line 51 – e.g. “hologram”
Hardware Connections:
Attach the SparkFun LTE Cat M1/NB-IoT Shield to your Arduino
Power the shield with your Arduino – ensure the PWR_SEL switch is in
the “ARDUINO” position.
//Click here to get the library: http://librarymanager/All#SparkFun_LTE_ … no_Library
#include <SparkFun_LTE_Shield_Arduino_Library.h>
// We need to pass a Serial or SoftwareSerial object to the LTE Shield
// library. Below creates a SoftwareSerial object on the standard LTE
// Shield RX/TX pins:
// Note: if you’re using an Arduino board with a dedicated hardware
// serial port, comment out the line below. (Also see note in setup)
// SoftwareSerial lteSerial(8, 9);
// Create a LTE_Shield object to be used throughout the sketch:
LTE_Shield lte;
// To support multiple architectures, serial ports are abstracted here.
// By default, they’ll support AVR’s like the Arduino Uno and Redboard
// For example, on a SAMD21 board SerialMonitor can be changed to SerialUSB
// and LTEShieldSerial can be set to Serial1 (hardware serial port on 0/1)
#define SerialMonitor Serial
#define LTEShieldSerial Serial2
// #define LTEShieldSerial lteSerial
void printInfo(void);
void serialWait();
void printOperators(struct operator_stats * , int );
// Network operator can be set to either:
// MNO_SW_DEFAULT – DEFAULT
// MNO_ATT – AT&T
// MNO_VERIZON – Verizon
// MNO_TELSTRA – Telstra
// MNO_TMO – T-Mobile
const mobile_network_operator_t MOBILE_NETWORK_OPERATOR = MNO_ATT;
const String MOBILE_NETWORK_STRINGS = {“Default”, “SIM_ICCD”, “AT&T”, “VERIZON”,
“TELSTRA”, “T-Mobile”, “CT”};
// APN – Access Point Name. Gateway between GPRS MNO
// and another computer network. E.g. "hologram
const String APN = “Broadband”; //ATT: Broadband / nxtgenphone, ATT 5G: nrbroadband
// This defines the size of the ops struct array. Be careful making
// this much bigger than ~5 on an Arduino Uno. To narrow the operator
// list, set MOBILE_NETWORK_OPERATOR to AT&T, Verizeon etc. instead
// of MNO_SW_DEFAULT.
#define MAX_OPERATORS 5
#define DEBUG_PASSTHROUGH_ENABLED
void setup() {
int opsAvailable;
struct operator_stats ops[MAX_OPERATORS];
String currentOperator = “”;
bool newConnection = true;
SerialMonitor.begin(115200);
while (!SerialMonitor) ; // For boards with built-in USB
SerialMonitor.println(F(“Initializing the LTE Shield…”));
SerialMonitor.println(F(“…this may take ~25 seconds if the shield is off.”));
SerialMonitor.println(F(“…it may take ~5 seconds if it just turned on.”));
// Call lte.begin and pass it your Serial/SoftwareSerial object to
// communicate with the LTE Shield.
// Note: If you’re using an Arduino with a dedicated hardware serial
// port, you may instead slide “Serial” into this begin call.
if ( lte.begin(LTEShieldSerial, 9600) ) {
SerialMonitor.println(F(“LTE Shield connected!\r\n”));
} else {
SerialMonitor.println(“Unable to initialize the shield.”);
while(1) ;
// First check to see if we’re already connected to an operator:
if (lte.getOperator(&currentOperator) == LTE_SHIELD_SUCCESS) {
SerialMonitor.print(F("Already connected to: "));
SerialMonitor.println(currentOperator);
// If already connected provide the option to type y to connect to new operator
SerialMonitor.println(F(“Press y to connect to a new operator, or any other key to continue.\r\n”));
while (!SerialMonitor.available()) ;
if (SerialMonitor.read() != ‘y’) {
newConnection = false;
while (SerialMonitor.available()) SerialMonitor.read();
if (newConnection) {
// Set MNO to either Verizon, T-Mobile, AT&T, Telstra, etc.
// This will narrow the operator options during our scan later
SerialMonitor.println(F(“Setting mobile-network operator”));
if (lte.setNetwork(MOBILE_NETWORK_OPERATOR)) {
SerialMonitor.print(F("Set mobile network operator to "));
SerialMonitor.println(MOBILE_NETWORK_STRINGS[MOBILE_NETWORK_OPERATOR] + “\r\n”);
} else {
SerialMonitor.println(F(“Error setting MNO. Try cycling power to the shield/Arduino.”));
while (1) ;
// Set the APN – Access Point Name – e.g. “hologram”
SerialMonitor.println(F(“Setting APN…”));
if (lte.setAPN(APN) == LTE_SHIELD_SUCCESS) {
SerialMonitor.println(F(“APN successfully set.\r\n”));
} else {
SerialMonitor.println(F(“Error setting APN. Try cycling power to the shield/Arduino.”));
while (1) ;
// Wait for user to press button before initiating network scan.
SerialMonitor.println(F(“Press any key scan for networks…”));
serialWait();
SerialMonitor.println(F(“Scanning for operators…this may take up to 3 minutes\r\n”));
// lte.getOperators takes in a operator_stats struct pointer and max number of
// structs to scan for, then fills up those objects with operator names and numbers
opsAvailable = lte.getOperators(ops, MAX_OPERATORS); // This will block for up to 3 minutes
if (opsAvailable > 0) {
// Pretty-print operators we found:
SerialMonitor.println(“Found " + String(opsAvailable) + " operators:”);
printOperators(ops, opsAvailable);
// Wait until the user presses a key to initiate an operator connection
SerialMonitor.println(“Press 1-” + String(opsAvailable) + " to select an operator.");
char c = 0;
bool selected = false;
while (!selected) {
c = SerialMonitor.read();
int selection = c - ‘0’;
if ((selection >= 1) && (selection <= opsAvailable)) {
selected = true;
SerialMonitor.println("Connecting to option " + String(selection));
if (lte.registerOperator(ops[selection - 1]) == LTE_SHIELD_SUCCESS) {
SerialMonitor.println(“Network " + ops[selection - 1].longOp + " registered\r\n”);
} else {
SerialMonitor.println(F(“Error connecting to operator. Reset and try again, or try another network.”));
} else {
SerialMonitor.println(F(“Did not find an operator. Double-check SIM and antenna, reset and try again, or try another network.”));
while (1) ;
// At the very end print connection information
printInfo();
void loop() {
// Loop won’t do much besides provide a debugging interface.
// Pass serial data from Arduino to shield and vice-versa
#ifdef DEBUG_PASSTHROUGH_ENABLED
if (LTEShieldSerial.available()) {
SerialMonitor.write((char) LTEShieldSerial.read());
if (SerialMonitor.available()) {
LTEShieldSerial.write((char) SerialMonitor.read());
#endif
void printInfo(void) {
String currentApn = “”;
IPAddress ip(0, 0, 0, 0);
SerialMonitor.println(F(“Connection info:”));
// APN Connection info: APN name and IP
if (lte.getAPN(&currentApn, &ip) == LTE_SHIELD_SUCCESS) {
SerialMonitor.println("APN: " + String(currentApn));
SerialMonitor.print("IP: ");
SerialMonitor.println(ip);
// Operator name or number
SerialMonitor.print(F("Operator: "));
// Received signal strength
SerialMonitor.println("RSSI: " + String(lte.rssi()));
SerialMonitor.println();
void printOperators(struct operator_stats * ops, int operatorsAvailable) {
for (int i = 0; i < operatorsAvailable; i++) {
SerialMonitor.print(String(i + 1) + ": ");
SerialMonitor.print(ops_.longOp + " (" + String(ops.numOp) + ") - ");_
switch (ops.stat) {
case 0:
SerialMonitor.println(F(“UNKNOWN”));
break;
case 1:
SerialMonitor.println(F(“AVAILABLE”));
break;
case 2:
SerialMonitor.println(F(“CURRENT”));
break;
case 3:
SerialMonitor.println(F(“FORBIDDEN”));
break;
void serialWait() {
Hey there.
We have seen one other forum post where someone was having issues with the Sara-R4 playing nice with their AT&T SIM card. Might just be a coincidence. We will keep an eye on this issue and investigate further if the problem is more wide spread.
In the meantime we would recommend that you try a different carrier and see if that resolves the issue. Considering that the hologram SIM card does work I think you might have a good chance of success with this method.
I hope this helps.
Thank you for your suggestions. I would appreciate it if you could point me to that post about SARA-R4 and AT&T.
The thing is both AT&T and Hologram SIM cards works with the module. With the Hologram SIM, I registered it once, and ever since, the module automatically connects to the network shortly after powering up—typically within a minute—and the NET light turns on.
However, this isn’t the case with the AT&T SIM. After initially registering with AT&T, the module works fine as long as it remains powered on. But if I turn off the device and then turn it back on, it fails to automatically reconnect to the network, and the NET light doesn’t turn on.
