Issue with Incorrect Encoder Values – SparkFun Auto pHAT and Hobby Motor with Encoder
Dear Customer Service Team,
I am currently using the following products:
  • SparkFun Auto pHAT for Raspberry Pi (ROB-16328)
  • Hobby Motor with Encoder - Metal Gear (ROB-16413)
I am encountering an issue where, when reading the encoder values, I occasionally receive incorrect readings. For example, out of 50 encoder counts, I sometimes get a value like “-120” in the middle of the series, and then the values continue as expected (e.g., “50”).
As this is my first time working with encoders, I am wondering if this behavior is normal, or if I might be doing something wrong.
To mitigate the issue, I have implemented a kind of damping in my code: values that deviate by more than 15% from the previous reading are ignored. However, I am wondering if there are other, more effective approaches to handle this problem.
Has anyone experienced something similar, or can suggest ways to improve the accuracy of the encoder readings?
Please post the code, using code tags.
If you are using interrupts, that behavior is a typical result of not following the stringent rules for interrupt coding.
I am using the code from the SparkFun Auto pHAT Hookup Guide. Here is a screenshot of the described effect.
Here’s the code from the encoder demo
#!/usr/bin/env python
# ex1_qwiic_dual_encoder_reader.py
# Simple Example demonstrating how to read encoder counts for the Qwiic Dual Encoder Reader (as part of the SparkFun Auto pHAT)
# Written by  SparkFun Electronics, May 2019
# This python library supports the SparkFun Electroncis qwiic
# qwiic sensor/board ecosystem on a Raspberry Pi (and compatable) single
# board computers.
# More information on qwiic is at https://www.sparkfun.com/qwiic
# Do you like this library? Help support SparkFun. Buy a board!
# Copyright (c) 2019 SparkFun Electronics
# Permission is hereby granted, free of charge, to any person obtaining a copy
# of this software and associated documentation files (the "Software"), to deal
# in the Software without restriction, including without limitation the rights
# to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
# copies of the Software, and to permit persons to whom the Software is
# furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in all
# copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
# AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
# OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
# SOFTWARE.
# Example 1
from __future__ import print_function
import qwiic_dual_encoder_reader
import time
import sys
def runExample():
    print("\nSparkFun Qwiic Dual Encoder Reader   Example 1\n")
    myEncoders = qwiic_dual_encoder_reader.QwiicDualEncoderReader()
    if myEncoders.connected == False:
        print("The Qwiic Dual Encoder Reader device isn't connected to the system. Please check your connection", \
            file=sys.stderr)
        return
    myEncoders.begin()
    while True:
        print("Count1: %d, Count2: %s" % (myEncoders.count1, \
            myEncoders.count2, \
        time.sleep(.3)
if __name__ == '__main__':
    try:
        runExample()
    except (KeyboardInterrupt, SystemExit) as exErr:
        print("\nEnding Example 1")
        sys.exit(0)
