Can’t fit the darn antennas GR#X ! Even the ones it was supplied with !
I have a number of ESP32 Based Cameras which also come with this kind of antenna fitting and have had no problems using it.
This has so far consumed so much time that I’m toying with the idea of consigning this (second) card to the bin and using my Ethernet connection (which works fine), but that’s going to mean some major re-configuration of all the other thingies i ssh into and my network.
I had a glance at the NVIDIA forum, but can’t find a section that looks like it deals with this basic kind of stuff.
We actually had trouble sourcing connectors as well, which is why we went with the [USB dongle in our kits. Despite the information provided, the WiFi cards (that were recommended) didn’t fit perfectly with standard U.FL connectors. The workaround, that was suggested to us, was to use “tape”. (*If you do find some connectors that work on a WiFi card, let us know.)
Wrt. the guide, I didn’t see that but have had a look at it now…only option left is to use the " tape" option which doesn’t look all that long term.
The video you found for me is excellent and I found it when doing “Homework” on the card many moons ago. Jim from Jetson Hacks is excellent), but he also admits that his video makes it look deceptively simple and that he pretty much had a nervous breakdown in the process.
My point is that I was ready for this…it definitely shouldn’t be that hard !
Thanks Santa_Impersonator
Looks like you are a few steps ahead of me !
Personally, maybe I can get my money back from Banggood and try to get my Windows 10 PC and Network to see my wired Ethernet connections (or just buy an extra monitor).
