I received my Jetson Orin Nano 8GB through Sparkfun.
Out of the box I was able to connect some peripherals and boot it up, no problem.
I then proceeded to install a case to keep it protected over the long haul, the " Yahboom Jetson Case for Jetson Nano Orin: New Protective case for NVIDIA Jetson Xavier NX/Jetson NANO/Orin NANO
Once installed, I turned the case power button on, it lit and so did the power indicator on the nano. the fan did not spin and nothing displayed on the screen.
I then carefully removed the nano from the case and all connections and plugging the nano in as before results in the same thing: power led indicator. no display. no fan.
Can anyone recommend any next steps? Did I brick my nano by simply putting it in a case very carefully?
