I’m intent on repairing a Konix Speedking joystick.
When you open it, the trigger switch can be accessed and replaced.
However, I want to replace the direction switches too. Trouble is they’re in a box.
My question is : do I use an expensive tool to get into the box? I was thinking a Dremel. Then, rebuild the box with new switches? I suppose I could use a 3D Printer to make an enclosure.
I’m confused - where to from here?
