hi!
Anybody tried running ucLinux on the IAR/olimex ARM9 kickstart board?
-S
hi!
-S
if you are talking about the cirrus logic ARM9 board from olimex, is unlike to run using uClinux because it has a MMU, instead of, you can run linux on it, that’s for sure!! just download the latest linux kernel from kernel.org and perform a ‘make menuconfig’, etc, etc…
good luck!
he means STR912-SK board we manufacture for ST/IAR, no it can’t run uclinux as it have not enough ram
Tsvetan
-Thanks
what is the absolut smalest RAM footprint uClinux can run on?
I migth be wrong! but I believe this controller comes with an external memory interface… so in theory you can extend it flash memory…
my 2 cents!
op! I see, you don’t have ram!! my bad
