kit 14418 - circuit 5c - mismatch between the wiring drawing and program
the drawing and the program list are not the same.
drawing- PWMA connected to D13, program list - PWMA connected to D11.
drawing - PWMB connected to D8, program list - PWMB connected to D10.
after cheking and recheking the wiring .
forward - goes ok.
with an obstacle- right motor - goes forward.
left motor - stops
backwards - never goes.
could the PWNA , PWMB be the reason.
Thank you Jossef
yossadsl@bezeqint.net
Hi Jossef,
If you are following along with the printed guide for the Inventor’s Kit v4.0, there are several known issues covered in our [Errata Document including the issue you have noticed with Circuit 5C. The [Online Guide has all of these errors fixed so that is the guide we recommend following along with, when possible.](https://learn.sparkfun.com/tutorials/sparkfun-inventors-kit-experiment-guide---v40)](https://www.sparkfun.com/SIKerrata)
