Lilypad problems uploading to board
I’m having problems with my lilypad Arduino, I already see all the suggestions from the FAQ but I’m still having problems.
This is the message the appears every time that I try to use my lilypad, Arduino.
Arduino: 1.8.13 (Windows Store 1.8.39.0) (Windows 10), Placa:“LilyPad Arduino, ATmega328P”
O sketch usa 924 bytes (3%) de espaço de armazenamento para programas. O máximo são 30720 bytes.
Variáveis globais usam 9 bytes (0%) de memória dinâmica, deixando 2039 bytes para variáveis locais. O máximo são 2048 bytes.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x51
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x51
Which Lilypad board do you have and how is it connected to your computer?
Are you sure you have selected the right COM port?
