Loading Arduino Library for AzureWave Thing Plus
I just received the AzureWave Thing Plus (AW-CU488) and placed the URL for the JSON file in the Additional Boards Manager URLs text box with the other URLs.
The URL was copied from the “getting started” instructions on the Sparkfun page:
https://github.com/ambiot/ambd_arduino/ … index.json
Clicking through I can see it being loaded. However, the Boards Manager does not find anything ‘Realtek’
Has anyone else seen this? If so, how is this problem solved?
The photos in the guide indicate the board should be AW-CU 488 AzureWave ThingPlus https://learn.sparkfun.com/tutorials/az … up-arduino (under the Ameba menu, perhaps?)
That would be fine if anything showed up in the Boards Manager. The problem is that there are no boards appearing if I type ‘realtek’ or ‘ameba’ in the search box.
There are no boards listed for me to choose.
I’ve tried many times. None succeed.
Double check the driver being used too https://learn.sparkfun.com/tutorials/az … usb-driver and the steps here if that doesn’t work https://learn.sparkfun.com/tutorials/az … leshooting
