I updated the firmware of the Sparkfun RTK Express +(Rovers) and Sparkfun RTK Surveyor (Base) and I have a question regarding the Max Log Time and the Max log length:
*I understood that with the new firmware we can have many logs of 2880 minutes as the SD Card allows it. In our project, we need to have a continuous measurement of a position for at least a month, so with this upgraded firmware version Can we obtain that measurement for that period of time, or are we still restricted to the 2880 minutes and then logging will cease?
*We have an SD card (32GB) do you know if a 32Gb store will be enough to measure the desired period of time?
*If we were restricted, Would you have a recommendation or a tutorial to change this configuration and allows us to measure for a longer period of time?
Thank you so much in advance for your help.
